TNY_122436's avatar
TNY_122436
Dec 23, 2013
Redirect iRule with URI redirection and pool distribution
I have an iRule that redirects URI containing certain syntax. I want to add a switch -glob statement so that the group of URI's that 'starts_with' the /page1, /page2, on so forth gets sent to a certain pool else defaults to pool green. I put in:
Code
switch -glob [HTTP::uri] starts_with
But that statement above returns me errors. I assume that can't be done or has to be done in some other format? Any help is greatly appreciated. Here's my existing code:
Code
if {[HTTP::uri] contains "/read.pdf"} {
       HTTP::redirect "https://www.main.com/menu" }
if {[HTTP::uri] starts_with "/Mypersonal/formula"} {
       HTTP::respond 301 Location "https://www.main.com/colors.html" }
switch -glob [HTTP::uri] {
"/page1" -
    "/page2" -
    "/page3" -
    "/index" -
    "/start" { pool orange }
    default { pool green }
Code
  • Please try this:
        if { [HTTP::uri] contains "/read.pdf" } {
        } elseif { [HTTP::uri] starts_with "/Mypersonal/formula" } {
                "/page1*" -
                "/page2*" -
                "/page3*" -
                "/index*" -
                "/start*" {
                    pool orange
                default {
                    pool green
    The -glob option allows you to use wildcards in the conditions, so a "starts_with" in a switch -glob would be a URI followed by a start "*".
  • Seems like there might be a syntax somewhere that is causing error when I compile the iRule. This is the error I get:
    Code
    01070151:3: Rule [/Common/test_redierct] error:
    line 1: [parse error: missing close-brace] [{
    "/page1*" -
    "/page2*" -
    "/page3*" -
    "/index*" -
    "/start*" {
    pool orange
    default {
    pool green
    line 2: [command is not valid in the current scope] [if { [HTTP::uri] contains  "/read.pdf" } {
    "/page1*" -
    "/page2*" -
  • There is in fact a missing closing brace.
                 "/page1*" -
                 "/page2*" -
                 "/page3*" -
                 "/index*" -
                 "/start*" {
                     pool orange
                 default {
                     pool green
