satish_81675
Nov 21, 2011RADIUS Traffic Management for BIG-IP v10
hi,
we are trying to deploy the BIG-IP for Radius Servers Loadbalancing and have found the RADIUS Traffic Management BIG-IP v11, do we have the same for BIG-IP v10, or what are the things that changed from V10 to V11 with regards to DG-RADIUS Traffic Management for BIG-IP v11.
Thanks in Advance.
Satish
- nitass
Employee
i never setup f5 for load balancing radius; anyway, i do not see any v11 specific function in Appendix: Manual configuration table section of the deployment guide. so, i think it should also be fine in v10.
Deploying the BIG-IP System v11 with RADIUS Servers
http://www.f5.com/pdf/deployment-guides/radius-iapp-dg.pdf
