Steve_Franc
Jul 27, 2009Radius Monitor Question
I have a need to create a radius monitor. The canned radius monitor will not suffice because we can not use a static password. I can specify a valid username but will use an invalid password which will result in an Access-Reject. Is it possible to build a radius monitor that will consider an Access-Reject ok and keep the nodes marked up.
