Radius Load BNalancing & persistence
i want to load balance radius opacktes Received from radius server to datbase servers , also i want to persist connection sothat one user accouting packets sent from radius go to the same database server , my questions are :
1- i found i need to use Radius profiles :
http://support.f5.com/kb/en-us/prod...ml1226620
does this perisist based on attribute ? if yse so it says that at "persist attribute " i need to specify : attribute/value pair or code , i need an example how to type this attribute/value pair at GUI box ? and what is meant by code ?
2- will this profile load balance , or i need to choose loada balancing method from under Pool ( because guide above says : ( When you configure a RADIUS type of profile, the BIG-IP system can send client-initiated RADIUS messages to load balancing servers. The BIG-IP system can also ensure that those messages are persisted on the servers ) . so it syas that thsi profile will load balance ?
- What_Lies_Bene1
You can find a list of AVP names here: http://en.wikipedia.org/wiki/RADIUSAttribute_value_pairs
This SOL suggests that you still need to select a load balancing method at the Pool level: http://support.f5.com/kb/en-us/solutions/public/12000/100/sol12140.html?sr=24980010 - nitass
Employee
is traffic from radius to database server radius?
for persist attribute, it is avp type. avp 1 is user-name (e.g. john).[root@ve10:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.79:1812 ip protocol 17 profiles { myradius {} udp {} } } [root@ve10:Active] config b profile myradius list profile radius myradius { defaults from radiusLB persist avp "1" } [root@ve10:Active] config b persist show all PERSISTENT CONNECTIONS | Mode universal Value john | virtual 172.28.19.79:1812 node 172.28.19.251:1812 age 2sec - SSHSSH_97332
Thanks Steve & Nitass
