rfelsburg_12081
Mar 20, 2013Question regarding port passthrough to pools
Basically, we have a pool setup with each member being
member1.example.com:0
member2.example.com:0
with a vip of lb.example.com listening on all ports.
Each pool member recieves the port passed by the client via the URL. I'm looking to change the port that is passed to the pool member though, so that if the user enters: lb.example.com:8080, the port passed to the member pool is 8082 instead of 8080, as if the user had entered lb.example.com:8082.
I wrote my existing iRule, thinking that the port passed to the pool, was simply the one in the Host header. It's not. Even after modifying the host header, the connection goes onto the original port. Any thoughts? Please let me know if I haven't explained it well enough, I'll snag actual definitions.
For a little scope, the idea is to abstract the port away from the originating URL, and the pool members completely. So that the iRule alone controls what port is gone to, and instead of having a pool for each port, we have a single pool that picks up the port from the iRule.
set new_host "[getfield [HTTP::host] : 1]:8082"
HTTP::header replace Host "$new_host"
- nitass
Employee
is it something like this? i assume http path is in "/port number/something" form.[root@ve10:Active] config b virtual bar list virtual bar { translate service enable snat automap pool foo destination 172.28.19.252:any ip protocol 6 rules myrule profiles { http {} tcp {} } } [root@ve10:Active] config b pool foo list pool foo { members { 200.200.200.101:any {} 200.200.200.111:any {} } } [root@ve10:Active] config b rule myrule list rule myrule { when CLIENT_ACCEPTED { set reselect 0 } when LB_SELECTED { if { $reselect } { return } log local0. "path [HTTP::path]" if { [scan [HTTP::path] {/%d/%*s} port] == 1 } { log local0. "port $port" log local0. "\[LB::server addr\] [LB::server addr]" set reselect 1 LB::reselect log local0. "LB::reselect" node [LB::server addr] $port log local0. "node [LB::server addr] $port" } } when SERVER_CONNECTED { log local0. "client [IP::client_addr]:[TCP::client_port] server [IP::remote_addr]:[TCP::remote_port]" } } [root@ve10:Active] config tail -f /var/log/ltm Mar 21 08:46:07 local/tmm info tmm[4950]: Rule myrule : path /8082/something Mar 21 08:46:07 local/tmm info tmm[4950]: Rule myrule : port 8082 Mar 21 08:46:07 local/tmm info tmm[4950]: Rule myrule : [LB::server addr] 200.200.200.101 Mar 21 08:46:07 local/tmm info tmm[4950]: Rule myrule : LB::reselect Mar 21 08:46:07 local/tmm info tmm[4950]: Rule myrule : node 200.200.200.101 8082 Mar 21 08:46:07 local/tmm info tmm[4950]: Rule myrule : client 172.28.19.251:36214 server 200.200.200.101:8082 Mar 21 08:46:28 local/tmm info tmm[4950]: Rule myrule : path /82/something Mar 21 08:46:28 local/tmm info tmm[4950]: Rule myrule : port 82 Mar 21 08:46:28 local/tmm info tmm[4950]: Rule myrule : [LB::server addr] 200.200.200.111 Mar 21 08:46:28 local/tmm info tmm[4950]: Rule myrule : LB::reselect Mar 21 08:46:28 local/tmm info tmm[4950]: Rule myrule : node 200.200.200.111 82 Mar 21 08:46:28 local/tmm info tmm[4950]: Rule myrule : client 172.28.19.251:48129 server 200.200.200.111:82 - rfelsburg_12081
Close, except, instead of the port being in the path, they want to set the port just via the iRule.
Either way this worked perfectly, thank you so much.
-Rob
