supportrsd_1762's avatar
supportrsd_1762
11 years ago
Question about a known issue (https://support.f5.com/kb/en-us/solutions/public/15000/400/sol15448.html)
Hello, while im prepering to upgrade my f5:s i ran into this issue https://support.f5.com/kb/en-us/solutions/public/15000/400/sol15448.html
Im going to use a version where this is fixed (11.5), the question is if it will be any problem when i go from 11.3 to 11.5
(i have three certificate that is imported with spaces)
  • Hmm, is still got problem with the certificate that did not get rolled into the new partition. I solved it by copying them from the active partition and put them in the right folder.
  • kunjan's avatar
    kunjan
    Is it because the 11.3 ucs backup file itself skipped these certs due to the space naming?
    • supportrsd_1762's avatar
      supportrsd_1762
      I dont really know, the certificate was still in the config, but the certificates where not copied to the new partition, also i had to rename the certificate and remove the spaces+rename them in the bigip.conf.
  • Is it because the 11.3 ucs backup file itself skipped these certs due to the space naming?
      supportrsd_1762
