nyklon_42006
Oct 14, 2008proxypass not changing response header properly
I am using proxypass for reverse proxy functionality and it is working fine except for one site. This site responds to the client with a new http header as follows
Changing response header Location: index.cfm?CFID=6069&CFTOKEN=83747944 with index.cfm?CFID=6069&CFTOKEN=83747944host.outside.com/atms
It is not adding in the required & between the end of the token and the host name. the header should be changed to:
index.cfm?CFID=6069&CFTOKEN=83747944&host.outside.com/atms
Any idea why it is doing the responses correctly for all the other sites running through proxypass but for this one it is not including the &
Without the & to differentiate the token from the host it goes straight to an error page.
- nyklon_42006
or is there a way that i can have this one site skip the http_response section of proxypass?
