ProxyPass Help
New to the F5 and needing to get the ProxyPass iRule working. The site receives HTTPS but the pool only work on HTTP. The iRUle is in place on the VIP and the datagroup is named ProxyPassVIPNAME (case sensitive). I turned on verbose logging in the ProxyPass iRule. All I get is bad host name and here is what the log shows.
May 2 10:18:55 rtplf502 info tmm[10361]: Rule /Common/ProxyPass : VS=/Low-Public/pubECDS, Host=www.project.org, URI=/: Checking Location=, $protocol=
May 2 10:18:55 rtplf502 info tmm[10361]: Rule /Common/ProxyPass : VS=/Low-Public/pubECDS, Host=www.project.org, URI=/: Checking Content-Location=, $protocol=
May 2 10:18:55 rtplf502 info tmm[10361]: Rule /Common/ProxyPass : VS=/Low-Public/pubECDS, Host=www.project.org, URI=/: Checking URI=, $protocol=
May 2 10:18:55 rtplf502 info tmm[10361]: Rule /Common/ProxyPass : VS=/Low-Public/pubECDS, Host=www.project.org, URI=/favicon.ico: Found Rule, Client Host=www.project.org, Client Path=/, Server Host=https:, Server Path=//surveys.rti.org/ecds/
May 2 10:18:55 rtplf502 info tmm[10361]: Rule /Common/ProxyPass : VS=/Low-Public/pubECDS, Host=www.project.org, URI=/favicon.ico: Using default pool /Low-Public/pubDotNet2Prod
May 2 10:18:55 rtplf502 info tmm[10361]: Rule /Common/ProxyPass : VS=/Low-Public/pubECDS, Host=www.project.org, URI=/favicon.ico: New Host=https:, New Path=//surveys.rti.org/ecds/favicon.ico
May 2 10:18:55 rtplf502 info tmm[10361]: Rule /Common/ProxyPass : VS=/Low-Public/pubECDS, Host=www.project.org, URI=/favicon.ico: 400 response from /Low-Public/pubDotNet2Prod 1.1.1.1%200 80
May 2 10:18:55 rtplf502 info tmm[10361]: Rule /Common/ProxyPass : VS=/Low-Public/pubECDS, Host=www.project.org, URI=/favicon.ico: Checking Location=, $protocol=
May 2 10:18:55 rtplf502 info tmm[10361]: Rule /Common/ProxyPass : VS=/Low-Public/pubECDS, Host=www.project.org, URI=/favicon.ico: Checking Content-Location=, $protocol=
May 2 10:18:55 rtplf502 info tmm[10361]: Rule /Common/ProxyPass : VS=/Low-Public/pubECDS, Host=www.project.org, URI=/favicon.ico: Checking URI=, $protocol=
Not sure how to read the log info to determine what is or is not working.
DSP
- uni
Altocumulus
The line below shows your problem. It says
butNew Host=https:,
. The datagroup entry looks to be incorrectly formatted. Can you post the contents of the datagroup?New Path=//surveys.rti.org/ecds/favicon.icoMay 2 10:18:55 rtplf502 info tmm[10361]: Rule /Common/ProxyPass : VS=/Low-Public/pubECDS, Host=www.project.org, URI=/favicon.ico: New Host=https:, New Path=//surveys.rti.org/ecds/favicon.ico
