Pete_Renaud_734's avatar
Pete_Renaud_734
Apr 14, 2009
Proxies and persistence
Source address persistence profiles don't work when a client traverses through a proxy. Is there some way to incorporate source address and source port in a iRule, basically to persist on the source port being used by the client?
  • I believe you could do this by the following examples using Universal Persistence
    Both Client and source port
     when CLIENT_ACCEPTED {
       persist uie [concat [IP::remote_addr] [TCP::remote_port]]
    or
       persist uie [concat [IP::remote_addr] [UDP::remote_port]]
    or
    Just the source ports
       persist uie [TCP::remote_port]
    or
       persist uie [UDP::remote_port]
    Hope this helps
    CB
