Wasfi_182818
Altostratus
Oct 18, 2016Protecting an i-rule inserted cookie using the ASM TS cookie
Hi;
Can I use the ASM TS cookie to protect a cookie generated on the BIG-IP using an i-rule. I mean protect it from tampering. would this be possible if I added the i-rule generated cookie to the enforced cookies list.
Kindly Wasfi
- Tikka_Nagi_1315Historic F5 Account
It should be possible depending upon the point when/where you insert the cookie in an iRule. Please share the iRule as it would help clarify what you are trying to achieve.
- Wasfi_182818
Altostratus
The i-rule applies to the http response. Bound to the LTM virtual server. Unfortunately, I can not provide more details than that.
Kindly Wasfi
