Sam_81197
Aug 02, 2010Protected Workspace: Could Not Start Protected Workspace
My notebook is running in WINXP Professional SP3. I am using Firefox 3.6.8.
After I clicked "Yes, Virtual desktop will be started", there was a popup shown with message, 'Preparing the new profile'. Then it disappeared. After a while, the following error dialog box was displayed:
"Protected Workspace: Could not start Protected Workspace".
I tried on IE 7.0 also. Also the same error result.
My Windows Firewall is on. I also install Trend Micro OfficeScan client. No other 3rd-party security related software installed.
What should I do right now ?
- Mike_61719
Cirrus
Install the pws hotfox from f5 if using 6.0.3. Other options include removing the Microsoft hf kb955759 or use the unregister tool Microsoft made for the Indeo codec. - Sam_81197
Still cannot solve the problem. Any other suggestions? - Don_Ryles_52501
Have you seen http://support.f5.com/kb/en-us/solutions/public/8000/100/sol8119.html
They say fixed in version 6.0.3 but what version are you running?
Kevin S. - Mike_61719
Cirrus
Sam,
Can you try this for me? It will unregister the Indeo Codec. Close all instances of IE (kill all processes) and try again after you complete the .MSI setup.
http://go.microsoft.com/?linkid=9701991 - Sam_81197
Posted By ksadler on 08/05/2010 01:41 AM
Have you seen http://support.f5.com/kb/en-us/solu...l8119.html
Kevin S.
I am using WINXP SP3, not VISTA. The link is irrelevant. - Sam_81197
Posted By Mike on 08/05/2010 06:49 AM
Sam,
I will try later. Keep you updated.
