Proc caching in irules? It is driving me crazy
It looks like there is some kind of unpredictable caching with proc's in irules.
I am using a local proc in a single irule and I have found that while debugging an irule it seems like some changes to the proc don't take effect. Log commands are one thing among other select statements/command I have had problems with.
I wasn't sure, but then after coming to my wit's end I just copy/pasted the proc into a second proc in the same irule and just added a character on the end of the proc name and all of a sudden the log commands are working if I call the renamed proc
Before renaming the proc in the irule, i tried unassigning the irule to the vs and reassinging,obviously updating/saving the irule, but nothing worked. The proc rename worked and I would guess an irule rename would work as well as a workaround
Has anyone else had this bizarre mind numbing experiencing with procs? Is this by design and it is just not published/documented?
Is there anyway to clear this caching when debugging irules/procs?
Thanks Matt
Not sure about procs specifically, but iRules are executed in connection based context, and updating the iRule does not change it for existing connections. Chrome for instance has a tendency to re-use connections and unless you let the connection time out or restart the browser. Could that have been your problem?
/Patrik
- Kevin_Stewart
Employee
The good news is that you're not crazy and have no need for sharp objects. There's already at least one case open (C1521235) and this problem, I believe, still exists (as of 11.5.1).
- IheartF5_45022
Nacreous
I've been given ID449900 as a reference for this. I'll update when I get a fix!!
