Ian_McKenna_113's avatar
Ian_McKenna_113
May 11, 2006
Problems with Monitor - get_template_list()
I have problems extracting template_type using Monitor-get_template_list. I have no problems extracting "template_name".
Should be a minor error, but being not a programmer I am stuck.
Has anybody an idea?
Source-code below.
Tanks in advance
Ian
my $MonitorInfo = SOAP::Lite
-> uri('urn:iControl:LocalLB/Monitor')
-> proxy("$sProtocol://Host:
$sPort/iControl/iControlPortal.cgi");
eval { $MonitorInfo->transport->http_request->header
'Authorization' =>
'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')
my $monitor_address;
my $soapResponse = $MonitorInfo->get_template_list();
&checkResponse($soapResponse);
my @monitor_list = @{$soapResponse->result};
my $templ_name;
my $templ_type;
my$i = 0;
foreach $monitor_address (@monitor_list)
$templ_name = $monitor_address->{"template_name"};
$templ_tpye = $templ_->{"template_type"};
printf("MONITOR %15s - TYPE %15s \n", $templ_name, @templ_type);
$i++;
  • Your line for getting the template type
    has a few problems. First, your variable has a typo (templ_tpye) and you are getting the member from a variable named (templ_) which I don't see defined in your code anywere. Changing this that line to this:
    $templ_type = $monitor_address->{"template_type"}
    should fix it for you.
    Here's some code that illustrates how to use this method:
    !/usr/bin/perl
     The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5
     Software Development Kit for iControl"; you may not use this file except in
     compliance with the License. The License is included in the iControl
     Software Development Kit.
     Software distributed under the License is distributed on an "AS IS"
     basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
     the License for the specific language governing rights and limitations
     under the License.
     The Original Code is iControl Code and related documentation
     distributed by F5.
     The Initial Developer of the Original Code is F5 Networks,
     Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004 F5 Networks,
     Inc. All Rights Reserved.  iControl (TM) is a registered trademark of F5 Networks, Inc.
     Alternatively, the contents of this file may be used under the terms
     of the GNU General Public License (the "GPL"), in which case the
     provisions of GPL are applicable instead of those above.  If you wish
     to allow use of your version of this file only under the terms of the
     GPL and not to allow others to use your version of this file under the
     License, indicate your decision by deleting the provisions above and
     replace them with the notice and other provisions required by the GPL.
     If you do not delete the provisions above, a recipient may use your
     version of this file under either the License or the GPL.
    use SOAP::Lite + trace => qw(method debug);
    use SOAP::Lite;
    use MIME::Base64;
    BEGIN {push (@INC, "..");}
    use iControlTypeCast;
     Validate Arguments
    my $sHost = $ARGV[0];
    my $sPort = $ARGV[1];
    my $sUID = $ARGV[2];
    my $sPWD = $ARGV[3];
    my $sProtocol = "https";
    if ( ("80" eq $sPort) or ("8080" eq $sPort) )
    $sProtocol = "http";
    if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") )
    die ("Usage: LocalLBMonitor.pl host port uid pwd\n");
     Transport Information
    sub SOAP::Transport::HTTP::Client::get_basic_credentials
    return "$sUID" => "$sPWD";
    $Monitor = SOAP::Lite
    -> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
    eval { $Monitor->transport->http_request->header
    'Authorization' =>
    &getMonitorTemplates();
     sub getMonitorTemplates
    sub getMonitorTemplates()
    $soapResponse = $Monitor->get_template_list();
    @MonitorTemplateList = @{$soapResponse->result};
    foreach $MonitorTemplate (@MonitorTemplateList)
    $template_name = $MonitorTemplate->{"template_name"};
    $template_type = $MonitorTemplate->{"template_type"};
    print "$template_name - $template_type\n";
     sub checkResponse
    sub checkResponse()
    my ($soapResponse) = (@_);
    if ( $soapResponse->fault )
    print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
    exit();
    -Joe
