Brantly_Perry_1
Aug 17, 2010Problems monitoring web page content - LTM v. 9.4.x
Hey everyone. I'm trying to set up what I thought was a pretty straight forward health monitor. This is pretty typical of what I've done with other systems, except this one will not all my node to be marked up.
Trying to monitor content at the following URL:
http://hrsdr/hmcng_web/login.jsp
My string is:
GET /hmcng_web/login.jsp HTTP/1.1\r\nHost: hrsdr\r\nConnection: Close
I've been sitting here for a couple hours making changes and tweaks to my syntax with no luck.
Any suggestions? Thanks!
- hoolio
Hi Brantly,
A receive string of 'GET /hmcng_web/login.jsp HTTP/1.1\r\nHost: hrsdr\r\nConnection: Close' should work for 9.4.x. What is the receive string your'e using?
You can check this page for tips on troubleshooting LTM monitors:
http://devcentral.f5.com/wiki/default.aspx/AdvDesignConfig/TroubleshootingLtmMonitors.html
Aaron - Brantly_Perry_1
Thank you Aaron. My receive string is:
Use a valid HRS username and password
I will check out the link you sent. Appreciate your time. - Brantly_Perry_1
Interesting. Connection Refused. Wonder why? The webpage comes up fine:
14:18:16.656245: send_active_service_ping: addr=::ffff:30.248.91.25:9002 writing GET /hmcng_web/login.jsp HTTP/1.1
Host: hrsdr
Connection: Close
14:18:16.656266: (_send_active_service_ping): addr=::ffff:30.248.91.25:9002 sent ping
14:18:16.656280: (_main_loop): wfd selected for addr=::ffff:30.248.91.25:9020 pending=1
14:18:16.656293: (_send_active_service_ping): addr=::ffff:30.248.91.25:9020
14:18:16.656310: (_connect_to_service): addr=::ffff:30.248.91.25:9020 connect: Connection refused
14:18:16.656341: (_send_active_service_ping): addr=::ffff:30.248.91.25:9020 unable to connect; giving up
14:18:16.656365: (_main_loop): wfd selected for addr=::ffff:30.248.91.25:9001 pending=1
14:18:16.656379: (_send_active_service_ping): addr=::ffff:30.248.91.25:9001
14:18:16.656400: send_active_service_ping: addr=::ffff:30.248.91.25:9001 writing GET / - smp_86112
It looks like this monitor is checking multiple pool members: port 9001, 9002, and 9020. The 9020 is being refused, but you referenced port 9002 at the top. Are you sure you're looking at the right pool members? - Brantly_Perry_1
Sorry, not blowing anyone off on my monitoring issue. I've been on vacation and just returned today. I'm jumping back into this issue now. - Brantly_Perry_1
Based on this output, I really don't know why this monitor isn't working:
[bperry@TNNASF5SF1:Standby] / curl -v http://30.248.91.11/hmcng_web/login.jsp
* About to connect() to 30.248.91.11 port 80
* Trying 30.248.91.11... connected
* Connected to 30.248.91.11 (30.248.91.11) port 80
> User-Agent: curl/7.15.3 (i686-redhat-linux-gnu) libcurl/7.15.3 OpenSSL/0.9.7l zlib/1.1.4
> Host: 30.248.91.11
> Accept: */*
< HTTP/1.1 200 OK
< Cache-Control: no-cache="set-cookie"
< Date: Mon, 30 Aug 2010 17:42:19 GMT
< Content-Length: 10405
< Content-Type: text/html; charset=ISO-8859-1
< Set-Cookie: JSESSIONID=mpLyM7tbdnBDnxPyC0wvgh2gL5GQqZsGxFGsdP1TphwG3tl5ycW0!722396472; path=/
< X-Powered-By: Servlet/2.4 JSP/2.0
< Set-Cookie: BIGipServerWeb_HRS=442234910.11555.0000; path=/
also, here is my receive string I found in the output:
var loginPanel = new Ext.Panel({
contentEl: 'login-panel',
title:'Welcome to the Healthy Returns System (HRS)',
frame:true,
width:500,
height:200,
autoShow:true,
renderTo:'ext-login-panel'
Anyone see anything I may be missing? Thanks. - smp_86112
This is what I've gathered from your post:
Send string:
GET /hmcng_web/login.jsp HTTP/1.1\r\nHost: hrsdr\r\nConnection: CloseReceive string:
Use a valid HRS username and passwordOutput:
}); var loginPanel = new Ext.Panel({ contentEl: 'login-panel', title:'Welcome to the Healthy Returns System (HRS)', frame:true, width:500, height:200, autoShow:true, renderTo:'ext-login-panel' });
If I have that correct, then your output does not contain the Receive String and I would expect the monitor to fail. Please clarify. - Brantly_Perry_1
Sorry for the confusion. The receive string I mentioned above is incorrect. The string configured on my bigip is actually:
Welcome to the Healthy Returns System - smp_86112
This may be a case of a bad Send String - but since I've never run 9.4.x, I don't know how many trailing \r\n are required. Hoolio said it should work without any, and he may be right. But if it were me, I'd also try one trailing \r\n, and then two if one didn't work.
I also suspect the web server may not like your Host: header. In the monitor you specify Host: hrsdr, but curl sets the host header to the IP: Host: 30.248.91.11.
Have you taken a network trace of the monitor traffic? Taking and/or analyzing network traces isn't something everyone knows how to do, so don't feel bad if you haven't and don't know how. But a network traces should isolate this problem very quickly. - Brantly_Perry_1
I did run a trace, and everything there seems to be in order as well. I'll go ahead and start fooling with the send string.
