isaumor_174545
Oct 20, 2014Problem with SSL
Hi All,
I´ve configure a system BIGIP (APM) but when in my web browser insert an IP public to access SSL pass the first step (certificate BIGIP) but just after appears in web browser the following message:
"https://
Do you known what´s the reason for the part my.logout.php3?errorcode=22?
How can I solve this problem?
Thanks in advanced.
- R_Eastman_13667Historic F5 AccountTry and add your IP address to the access policy under the tab "SSO/Auth Domains". Select Multiple Domains then add your Virtual Host IP address as a host. You will probably still get a certificate mismatch error in your browser, but APM should work.
- Amit_Karnik
What is the first check in the VPE policy ? Can you check the /var/log/apm and post the log messages for your session ?
