problem with HTTP auth (APM)
Hello,
I tried to configure the HTTP Auth object on the APM Access Policy. There is some strange issue that I am not able to identify.
I tried to make the POST request from an HTTP request client, I have configured the SAME POST with the same paramenters on the F5 but when I use the HTTP request client the response is 200 ok, when the HTTP POST is made from the F5 the web server returns the 302 code.
POST Request:
POST./xxx/portal.HTTP/1.1 Host:.10.1.1.1:9080 Accept:./ Content-Type:.application/x-www-form-urlencoded login_name:.xxxxxx
action=LoginAction&username=xxxxxx&password=xxxxxx&submit=Login
Anyone can suggest me some tests that may help me to troubleshoot the issue?
Thanks in advance.
- Michael__
Lets see if i got the problem right 🙂
Sounds to me as the 302 returned by the APM is the redirect to /my.policy which is the normal behavior with apm. To suppress the redirects from APM you could use "clientless-mode"
when HTTP_REQUEST { enable the clientless-mode so that users will not follow 302 used by APM HTTP::header replace "clientless-mode" 1 }maybe this helps to solve your issue.
Regards
Micha
- MDPF52_180608
Thank you Michael! I will try to explain better...so: The HTTP POST is the request that is sent by the HTTP Auth object in the APM Policy, the request that the BIG-IP sends to the Web Server. Currently, I am trying to figure if there is some HTTP header that is required from the Web Server in order to accept the POST request but at the moment the situation is the following: HTTP Requester client - POST Request OK (Elements: 1. Content-Type Header: application/x-www-form-urlencoded 2. Custom apm header : %apmvariable) 3. Body with data) Can you suggest me something? Thanks in advance, Regards.
- Michael_61033
Regards
Micha
- MDPF52_180608
