omar_padilla's avatar
omar_padilla
Apr 10, 2019
Problem timeoute connection pool member
hello, I have a small problem with a service I hope you can explain me well: I have a virtual server for a service which has 2 pool members, the application works but after 5 min I boot the application with a timeout, and apply the persistence of several types (source, coockie, ssl) I see the statistics of the persistence record and I do not see any problem, disable a node but the application bounces me, I have another VS that I create to connect directly to the node (forwarding_IP) the application by console also habre but in 5 min I bounce is a sesipon SSH, if I remove from the middle to the F5 I have no problems, can someone help me with any reference?
  • The issue is likely the layer 4 profile on the virtual server. The default TCP profile and the fastL4 profile both have a 5 minute idle timeout for tcp connections. Create a custom TCP profile with a longer idle timeout and assign to the virtual server. Note that the Standard type virtual server has a client-side tcp profile and a server-side tcp profile. You will need to configure both with a longer timeout.
