Otto_Mangold_10
Nov 16, 2016Problem running check-cert with iControlRest
Hi there!
Does anybody know in which version the iControlRest command mgmt/tm/sys/crypto/check-cert is supported? Can't access it on a 12.1.0 HF2 device. Am I making a mistake accessing it?
On https://devcentral.f5.com/wiki/iControlREST.APIRef_tm_sys_crypto_check-cert.ashx I cannot find that it is somehow depending on the version.
Thanks & Regards
