Problem of doing both TCP and HTTP editting
In my application (vs is TCP protocol with HTTP Profile), we'd like to - 1. insert metadata per each connection using TCP profile and it's access functions 2. We also want to preserve all existing HTTP profile and manipulation as it is, for example insert XFF in example below.
when CLIENT_ACCEPTED { metadata could be something else set metadata [IP::client_addr] TCP::payload replace 0 0 $metadata log local0. "Inserting TCP DATA to SERVER" TCP::release }
when HTTP_REQUEST { HTTP::header insert XFF [IP::client_addr] log local0. "Insert XFF header to SERVER" }
Question is: Is this a viable approach to BIG-IP internals? In other words, once metadata inserted would it impact HTTP state processing and introduce regression problems to any extend?
- hoolio
What are you trying to accomplish with the TCP payload insertion?
If you insert arbitrary data in the beginning of the TCP payload, you'll be prepending that data before the HTTP request line. I expect this will break the HTTP profile's parsing of the request line for the verb, URI and HTTP version. Consequently, I don't think this will work.
Aaron
- HenryX_171845
With following code, I found both TCP-INSERT and HTTP Header Insertion were successfully done (checked on receiving tcpdump).
when CLIENT_ACCEPTED { TCP::payload replace 0 0 "TCP-INSERT" TCP::release } when HTTP_REQUEST { HTTP::header insert HDR "HTTP-HEADER-INSERT" }Unfortunately if I add a TCP insertion fired at SERVER_CONNECTED, it show an error.
I think a thorough understanding of the events and state machines internal may be very helpful to debug.
Thanks for your thought.
