Pedro_Minas's avatar
Pedro_Minas
Nov 10, 2010
Problem Downloading
Hi
I'm having problems downloading a file via Big-IP LTM.
I have created a virtual service HTTP, when i try to download a file directly from de servers there is no problem... but when i try to download it via Big-IP it doesn't work...
Any clues?
  • were u able to start downloading?
    did it happen on every browser e.g. ie, ff?
  • Yep all the browsers have the same problem... It doesn't even starts to download...
  • web page is working fine, isn't it? only downloading has a problem, hasn't it?
    can u post your config here?
  • Everything is working fine...
    The only problem is downloading...
    I have a load balancing service http between 2 servers... with all the basic options... without irules or persistence...
  • i've no idea. anyway, if i were u, i would run tcpdump and compare packet between server-f5 and f5-client.
    the tcpdump command may look like this:
    tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap \(host vip and port vport\) or \(\(host poolip1 or host poolip2\) and port poolport\)
