Problem creating ILX plugin from iApp
I have an iApp template I've created that creates an ILX workspace. I am trying to create an ILX plugin that references the workspace but keep getting 'An error has occurred while trying to process your request.' when creating an iApp instance from the template.
The funny thing is the ILX plugin gets created and works fine - but can't click on the iApp instance without getting the error. I checked /var/log/ltm, /var/log/webui.log and a few other places and can't seem to find any info about the error. Here is the iApp template code:
set apppath "/Common/${tmsh::app_name}.app"
set lxtgz "http://xxxxx.tgz"
tmsh::create ilx workspace KeyID-APM-LX from-uri $lxtgz
set s "
ilx plugin KeyIDLX \{
from-workspace ${apppath}/KeyID-APM-LX
tmsh::create $s2 Replies
- Satoshi_Toyosa1Ret. Employee
Hi Jonathan,
Looks like the plugin creation part (
) is causing the issue. Other ilx related commands, such astmsh::create ilx plugin from-workspace
ortmsh::create ilx workspace
, do work. Will investigate.tmsh::create ilx workspace extensionSatoshi
Hi Jonathan,
Unfortunately, iRules LX is currently not fully supported by/with the TCL iApps infrastructure yet. If you wish to expedite our development effort, I advise you to raise a request for enhancement (RFE) to the F5 Support.
Thank you for reporting the issue and effective workarounds.
