Problem adding network interface to VM for Big-IP 11.3
I'm trying to add some interfaces to our Big-IP VM and it isn't going well. When I add the interfaces, we already have 4 defined, we lose access to the configuration GUI and SSH access to the VM. The only way to access the Big-IP is through the console from the Virtual Center GUI. This is a documented problem with running Big-IP under VMware (CR 137616) but the workaround doesn't work for us. It says to run the command "rm /var/db/mcpd*", which we can't from the TMSH shell. Any ideas how to get this thing working would be greatly appreciated.
- Thomas_Gobet_91
Can you tell us which role is assigned to your user ?
You should find Advanced Shell into "Terminal Access" parameter.- Dennis_Caffi_11
The role is Administrator and the Terminal Access is tmsh. The other selection is Disabled. This is the "admin" user. Should I create a new user? Also, how do I tell which version (Lab or trial) of Big-IP LTM VE we are running, or does that make a difference?
- Thomas_Gobet
- Thomas_Gobet
That makes no difference which version your BIG-IP is.
You have 2 options to connect into bash :
- Create an other user account to give adminitrator role with advanced shell allowed.
- Use root account which has advanced shell rights.
- Dennis_Caffi_11
Just tried to add another user. Selected "Administrator" as role but there were only 2 choices for Terminal Access, "Disabled" or "tmsh". This is getting very frustrating. I even placed a call to F5 support yesterday and haven't heard anything back yet. I can't believe anyone would actually pay money for this product. - Dennis_Caffi_11
We are unable to login as root. I've been told once the initial setup config has run, root is disabled.
- Thomas_Gobet_91
- Dennis_Caffi_11
- Thomas_Gobet_91
And what about using root account ? Can you tell us what version you're running on (not VE, lab or something like that) but the result of this command :
show sys version- Dennis_Caffi_11
Results are: Product BIG-IP Version 11.3.0 Build 2806.0 Edition Final Date Tue Nov 13 22:34:00 PST 2012
- Thomas_Gobet
- Thomas_Gobet
No it's not, root account is still enabled once initial setup is done.
But what can be different is the password. - Thomas_Gobet_91
Can you try to connect you with the root account and use the default password which is : default
About your issue on user creation, are you using partition ?
Because only users created under "Common" partition can have "Advanced shell" access.- Dennis_Caffi_11
Tried root with default password and what we set it to initially. Received "access denied" message. When creating a user I don't get to set a partition. A current user that has Common as the partition and Administrator role only has either "Disabled" or "tmsh" as Terminal Access choices.
- Thomas_Gobet
- Thomas_Gobet
Can you try to follow this solution to reset your root account password ?
http://support.f5.com/kb/en-us/solutions/public/13000/100/sol13121.html
- Dennis_Caffi_11
Tried this and it did not work. Booted in single user mode and used the passwd command to change root's password. It says it worked, but after reboot was unable to log in as root.
