Venkat_96085's avatar
Venkat_96085
Sep 09, 2009
Preserving Client IP address for SMTP traffic
We have a requirement to loadbalance two SMTP servers via F5 load balancers, Since we are using SNAT the real client IP is not visible to the smtp servers. Is there any option avaialble for the servers to see the client ip. I have earlier done a similar thing for HTTP traffic using Xforwarded-for, do you have something similar to smtp.
Thanks,
Venkat
  • Hi Venkat,
    Here is a discussion article about the very same thing you are looking for
    http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=57603
    CB
