Vidar_S_160491's avatar
Vidar_S_160491
Mar 18, 2015
Predictive Load Balancing prefering more busy servers than less busy servers over time
We have an immediate issue with our F5 LTM VE v11.5.1 0.0.110 Final. We've configured a number of pools to use the "Predictive (Member)" load balancing algorithm. This have been working fine over time, but currently the F5 seems to prefer the more busy node members over 2 servers having 0 connections at the moment.
Is there a logfile/stat file to examine to determine why the two nodes with 0 current users are not being prioritized over the more "busy" nodes?
  • Arie's avatar
    Arie
    Have you seen this?
    Observed (member): Specifies that the system ranks nodes based on the number of connections. Nodes that have a better balance of fewest connections receive a greater proportion of the connections. This method differs from Least Connections (member), in that the Least Connections method measures connections only at the moment of load balancing, while the Observed method tracks the number of Layer 4 connections to each node over time and creates a ratio for load balancing. This dynamic load balancing method works well in any environment, but may be particularly useful in environments where node performance varies significantly.
    Predictive (member): Uses the ranking method used by the Observed (member) methods, except that the system analyzes the trend of the ranking over time, determining whether a node's performance is improving or declining. The nodes in the pool with better performance rankings that are currently improving, rather than declining, receive a higher proportion of the connections. This dynamic load balancing method works well in any environment.
  • Yes I have. But the help text doesn't explain how it is analyzing the trend of the ranking over time, and how I can (or can not) examine the actual trend.
    Is there a stat/logfile on the server where I can examine the data its basing the trend stats on?
