cgaines22_14499's avatar
cgaines22_14499
Mar 22, 2016
PowerShell Help with JSON and Invoke-WebRequest
This is the F5
$MyLTM_IP = '10.5.183.4'
Load the SnapIn first
Add-PSSnapIn iControlSnapIn
Need to create Login
$secpasswd = ConvertTo-SecureString 'password1' -AsPlainText -Force$mycreds = New-Object System.Management.Automation.PSCredential ('user1', $secpasswd)
Initialize-F5.iControl first by logging into F5
Initialize-F5.iControl -HostName "$MyLTM_IP" -PSCredentials $mycreds
This shows the available partitions
(Get-F5.iControl).ManagementPartition.get_partition_list()
This command shows all of the actions available to the F5.
Invoke-WebRequest -Method GET  -URI '[https://10.5.183.4/mgmt/tm/ltm](https://10.5.183.4/mgmt/tm/ltm)'-Credential $mycreds
A modification of an existing object requires the PUT method, POST is for object creation.
Fails:
Invoke-WebRequest -Method POST -Uri '[https://10.5.183.4/mgmt/tm/ltm/pool](https://10.5.183.4/mgmt/tm/ltm/pool)' { "name":"cpg-pool2", "partition":"CL-COM_SELFSERV", "members" : [{"name":"10.5.183.199", "description":"Web server"}] }
Fails:
Invoke-WebRequest -Method POST -Uri '[https://10.5.183.4/mgmt/tm/ltm/pool/~CL-COM_SELFSERV~cpg-pool2](https://10.5.183.4/mgmt/tm/ltm/pool/~CL-COM_SELFSERV~cpg-pool2) [{"name":"10.5.183.199", "description":"Web server"}]'
Fails:
Invoke-WebRequest -Method POST -Uri '[https://10.5.183.4/mgmt/tm/ltm/node/~CL-COM_SELFSERV](https://10.5.183.4/mgmt/tm/ltm/node/~CL-COM_SELFSERV)' [{"name" : "10.5.183.199", "description" : "Web server"}]'
    PS U:> Invoke-WebRequest -Method POST -Uri '[https://10.5.183.4/mgmt/tm/ltm/pool/~CL-COM_SELFSERV~cpg-pool2](https://10.5.183.4/mgmt/tm/ltm/pool/~CL-COM_SELFSERV~cpg-pool2) [{"name":"10.5.183.199", "description":"Web server"}]'
    Invoke-WebRequest : The remote server returned an error: (401) Unauthorized.At line:1 char:1
    + Invoke-WebRequest -Method POST -Uri '[https://10.5.183.4/mgmt/tm/ltm/pool/~CL-COM](https://10.5.183.4/mgmt/tm/ltm/pool/~CL-COM) ...
    + CategoryInfo          : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest], WebException
    + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
I am trying to add a new Node 10.5.183.199 to the existing Pool cpg-pool2 that is located in the Partition CL-COM_SELFSERV. I have tried different variations and the Invoke-WebRequest works for other commands.
What am I missing other than not understanding where the ~ is used and when [ ] JSON is used?
  • Hi there!
    Looks like you're mixing REST and the snap-in.
    Also looks like you missed the pre-formatted code option in the forum which would make all the jumple above actually readable.
    I'll make you a deal:
    If you paste all your future questions in a proper format, I'll help you with the script. :)
    /Patrik
  • Try this if you want to use the iControl snapin:
    if ( (Get-PSSnapin | Where-Object { $_.Name -eq "iControlSnapIn"}) -eq $null ){
    If you don't want to use TLS1.2, comment the line below
    [Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12
    Authenticate
    $Success = Initialize-F5.iControl -Hostname 10.5.183.4 -Username "user1" -Password "password1"
    Get an iControl Handle
    $F5 = Get-F5.iControl
    $Poolname = "/CL-COM_SELFSERV/cpg-pool2"
    $Member = New-Object -TypeName iControl.CommonAddressPort
    $Member.address = "/CL-COM_SELFSERV/10.5.183.199"
    $Member.port = 80
    $f5.LocalLBPool.add_member_v2(@($Poolname), @(@($Member)))
    /Patrik
    • Brad_Parker's avatar
      Brad_Parker
      Icon for Cirrus rankCirrus
      For what its worth I would recommend using Invoke-RestMethod rather than Invoke-WebRequest. As for your question about getting a 401. You will need to authenticate with a get request before you send a PUT or POST. I'm not sure why this is the case, but it works.
    • cgaines22_14499's avatar
      cgaines22_14499
      Thanks Brad that changed the look of the Get request to a short return versus using Invoke-WebRequest. They both return values but Invoke-RestMethod seems to only refer to the object in the URI not the whole URI list. I will try the Get statement before the Post statement and see what occurs.
  • This builds 1 new Pool and puts 1 new Node in that Pool. Invoke-RestMethod and Invoke-WebRequest both work one returns more information in the final output. The node did not receive the description so I will have to keep on working on that part.
    Invoke-RestMethod -Method POST -Uri "https://10.5.183.4/mgmt/tm/ltm/pool" -Credential $mycreds -Body '{"name":"cpg-pool2","partition":"CL-COM_SELFSERV","members":[{"name":"10.5.183.199:80","address":"10.5.183.199","description":"Web server"}]}' -Headers @{"Content-Type"="application/json"}
