Power Status Check Commands
Can Some one please help me with big pipe and TMSH commands to check power supply status of chassis and blade?
- StephanManthey
Nacreous
Just run
tmsh show sys hardwarebigpipe platform show You can also get to them with our APIs via the System.SystemInfo.get_power_supply_metrics() method
-Joe
- rp1210_121071
thank you for the answer and what if it does not show the power status like in this case:
)(cfg-sync In Sync)(Active)(/Common)(tmos.sys.hardware) show
Chassis Information Maximum MAC Count 2 Registration Key -
Hardware Version Information Name cpld Type pic Model F5 CPLD Parameters -- -- version 0x8
Name cpus Type base-board Model Intel(R) Xeon(R) CPU @ 2.00GHz Parameters -- -- cache size 8192 KB cores 8 (cores/cpu:4) cpu MHz 2000.000
Name lop Type pic Model F5 Parameters -- -- Boot loader version 1.04 Firmware version 2.18
Name mainboard Type base-board Model F5 Parameters -- -- Assembly serial pca0290z00d9 Board type N/A Level 400 part N/A PCN level PCA-0290-05 REV A Revision N/A
Name qa-crypto2 Type crypto Model Intel Cave Creek Cryptographic Device Parameters -- -- version 1.0.0
Name qa-crypto3 Type crypto Model Intel Cave Creek Cryptographic Device Parameters -- -- version 1.0.0
Name qa-dc0 Type compress Model Intel Cave Creek(2), HW:C1, FW:0.9.0
Platform Name BIG-IP 4000 BIOS Revision OBJ-0433-xx Build: 1.11.132.0 09/17/2012 Base MAC 0:23:e9:51:bc:c0
System Information Type C113 Chassis Serial f5-wgsx-vsll Level 200/400 Part 200-0352-02 REV A Switchboard Serial
Switchboard Part Revision
Host Board Serial pca0290z00d9 Host Board Part Revision
