Shaun_85943
Apr 27, 2010PostgreSQL Monitor Documentation
Ok,
I'll admit that I'm probably just not looking in the right spot, but does anyone know where to find documentation on setting up the PostgreSQL monitor? I've been able to get a simple HTTP monitor up and running, but that only tells me the status of IIS. I also need the status of PostgreSQL and it looks easy enough to do but I can't figure it out.
- Shaun_85943
Ok,
Got one step further. I'm able to monitor PostgreSQL & IIS seperately for the same pool. Next question is, how do I setup one node to be down if both IIS & PostgreSQL are not both up? - hoolio
Hi Shaun,
To create a dependence, you can configure an alias port for the custom HTTP and postgresql monitors and then assign both monitors to both pools.
Aaron
