possible to have multi-layered irules ?
I need to make changes to an existing prod instance of F5 BIG-IP LTM VE 10.2.4.
It has a virtual server configured with a single iRule that contains 2 simple switch statements that parse host & uri and route to various pools.
For switch case ( pool ) , I need to add some redirect/rewrite functionality.
I would prefer not to alter the existing Rule - or alter it as little as possible.
Is it possible to "layer in" another irule ? So if the first irule gets to the switch case it routes to another irule ?
Alternately , is it possible to attach an irule to the destination pool so that it intercepts all traffic routed to that pool ?
- JRahm
Admin
yes, you could do something like that by using variables to do so. I would be careful at the maintainability of such a solution. But basically:
Rule 1
priority 100 when RULE_INIT { set static::trigger 0 } when HTTP_REQUEST { switch [LB::server pool] { "pool1" { set static::trigger 1 } "pool2" { set static::trigger 2 } "pool3" { set static::trigger 3 } } }Pool1 Rule
priority 110 when HTTP_REQUEST { if { $static::trigger == 1 } { do stuff } }Edit->actually, LB::server pool probably won't be very accurate in HTTP_REQUEST, so you might need to move some of the logic to a later event. The flow from iRule->iRule mapping stands though.
