supportn2_11211's avatar
supportn2_11211
15 years ago
Port Console : Prompt "CFE>"
Hello,
I have a problem with my BigIP 6900. The appliance is working well but I can't connect to the console port and it's blocked me to do an update.
When I am connecting to the console I don't see the bigip prompt but I am seeing this prompt :
CFE>
CFE>
CFE>
CFE>
CFE> ?
Invalid command: "?" Available commands: testheap, reset, echo, countdown, passthru, set, sleep, loop, erase, flash, memtest64, memtest32, f, e, d, u, reserve, batch, go, boot, load, save, ping, arp, ifconfig, show, unsetenv, printenv, setenv, help *** command status = -1
CFE>
When I do an aomreset reset I see that :
HELO
CPUI
L1CI
DRAM
COPY
RELO
ZBSS
L12F
GRel
MAIN
KMEM
CONS
FLS[
Bad 'baudrate' value "(null)", using default 19200
EXCS
CIOK
CFE version 1.5.1 for F5AOM (32bit,SP,LE,MIPS) [nub] Build Date: Tue Aug 26 11:04:50 PDT 2008 (f5cm@build10) Copyright (C) 2000,2001,2002,2003,2004,2005 Broadcom Corporation.
AREN
Initializing Arena.
DEVI
Initializing Devices.
CPU type 0x29006: 200MHz
Total memory: 0x4000000 bytes (64MB)
Total memory used by CFE: 0x83D00000 - 0x83F354C0 (2315456)
Initialized Data: 0x83D31100 - 0x83D32CF0 (7152)
BSS Area: 0x83D32CF0 - 0x83D334C0 (2000)
Local Heap: 0x83D334C0 - 0x83F334C0 (2097152)
Stack Area: 0x83F334C0 - 0x83F354C0 (8192)
Text (code) segment: 0x83D00000 - 0x83D30AB0 (199344)
Boot area (physical): 0x03CBF000 - 0x03CFF000
Relocation Factor: I:E4100000 - D:E4100000
ENVI
CFE
CFE
CFE>
What can I do to get back the control of my BipIP from the console ?
Thanks !
David
  • hoolio's avatar
    hoolio
    Hi David,
    I suggest you open a case with F5 Support. They can reference C751160 for some possible steps to resolving this issue.
    Aaron
