Yozzer's avatar
Yozzer
Jul 08, 2012
Pool not called
Hi
Is there any other configuration i need to perform to get the following irule to trigger correctly:
if {[HTTP::uri] contains "/test/"} {
log -noname local0. "should go to pool"
pool https_pool
The log command is executing (so i know the if command is being triggered) and the request is being sent to the https_pool pool but no response comes back from the server. I know the pool member is correct as when i change it i get a compilation error.
I added the following and i can see that the correct pool has been selected and the pool is up and accessible:
when LB_SELECTED {
  log local0. "Selected server: [LB::server]"
when LB_FAILED {
ASM is being used but the page i want to access has no restrictions.
I want requests to /test/ to go to a different pool which will handle the users login and then set the cookie for the same domain.
