supersharp_3604's avatar
supersharp_3604
May 04, 2018
Pool is changed when Ansible playbook is played again
When I add a Pool in my BIG-IP by the mean of Ansible module big_ip, the pool is correctly defined. Fine!
But when I play the task again, the pool is signaled as
changed
(in the Ansible stdout
PLAY RECAP
). It shoudn't because nothing was changed.
This occurs only when I define the
monitor
option for the pool in the task:
monitor_type: and_list
monitors: http
Whan I don't define a
monitor
option then I can play the taks again and the pool in seen as unchanged, as expected.
  1. Is it a normal behavior?
  2. What could I do to avoid it?
I need to see only the real changes in the PLAY RECAP because some handlers are triggered by changes.
Thank you for your help 🙂
