sandman748's avatar
sandman748
Sep 23, 2020
Please help with irule for pool selection based on custom http header
Hi all,
Could someone assist me with an irule that would look at a custom header callled X-Server-Pool. If "xyz" then this pool, if "abc" then this pool, else default.
I think this is a starting point but it doesnt appear to be working
  1. when HTTP_REQUEST {
  2. if { [HTTP::header exists X-SERVER-POOL] and [HTTP::header X-SERVER-POOL] equals "xyz" } {
  3. pool xyz
  4. } elseif [HTTP::header exists X-SERVER-POOL] and [HTTP::header X-SERVER-POOL] equals "abc" } {
  5. pool abc
  6. }
  7. }
  8. }
If no header exists it would hit default pool assigned to vip?
  • Hi sandman748,
    Can you look logs with this:
    	if { [HTTP::header exists X-SERVER-POOL] } {
    		log local0. "X-Server-Pool: [HTTP::header X-SERVER-POOL]"
    		switch [HTTP::header X-SERVER-POOL] {
    			"xyz" { pool xyz }
    			"abc" { pool abc }
    If no header exists, it hits the default pool. If no default pool exists, it drops. You can add default pool configuration in iRule with using else or switch.
    			"xyz" { pool xyz }
    			"abc" { pool abc }
    			default { defaultpool }
