mmm286's avatar
mmm286
4 years ago
please help newbie configuring Vlan's vmware
I'm trying to configure 3 interfaces in vmware workstation with bip-ip f5. The config in workstation is:
Vmnet0 -> host Only -> 10.1.1.0
Vmnet1 -> host Only -> 192.168.1.0 (management use)
Vmnet2 -> host Only -> 172.26.1.0
I have 2 VLAN'S:
external 4093 1.2
internal 4094 1.1
interfaces:
10.1.1.100 255.255.255.0 internal traffic-group-local-only Common
172.26.1.100 255.255.255.0 external traffic-group-local-only Common
I have in other worksation a windows with Vmnet2 and:
IPv4. . . . . . . . . . . . . . : 172.26.1.15
Mask. . . . . . . . . . . . : 255.255.255.0
Gateway . . . . : 172.26.1.100
But I can't do ping to the default gateway:
Sufijo DNS específico para la conexión. . :
Dirección IPv4. . . . . . . . . . . . . . : 172.26.1.15
Máscara de subred . . . . . . . . . . . . : 255.255.255.0
Puerta de enlace predeterminada . . . . . : 172.26.1.100
Please could you help me? Thanks and sorry for my English!
  • you may stop your firewall first. then ping 172.26.1.1 with both virtual machines. if you can you should turn off 172.26.1.100 's firewall and try it again.
  • Hi,
    Your configuration looks correct, but, how is the configuration of your server vlan? tagged or untagged? in virtual environments you need always to configure the VLANs as untagged.
