Persistence entries aren't mirrored to the standby unit when using iRules
Hi
I have an iRule configured on a VIP. This iRule select Pool1 or Pool2 based on the HTTP_Host. I removed any defaultpool configuration on my VIP to make sure only my iRule select them. I also have a default persistence profile attach to my VIP, so I do not add a persistence command into my iRules
On my primary unit I'm able to see all the persistence created but on my standby unit I should see all the same record but with 0sec of age but I didn't see anything. The list is empty on my standby units.
I double-checked on my persistence profile and I have the "Mirror persistence" check box enable.
Is there anyting related with my iRules or it's a basic mirror persistence issue ?
- nitass_89166
Noctilucent
I have a cluster of 3 LTM but one of them was a test and the licence is expired. I don't use it anymore but haven't remove it from the cluster. I have a sync failed for that one but my 2 other one are flaged as green.
the expired unit is not a next active device, is it?
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) show cm traffic-group ----------------------------------------------------------- CM::Traffic-Group Name Device Status Next Active ----------------------------------------------------------- traffic-group-1 ve11a.acme.local standby false traffic-group-1 ve11b.acme.local standby true traffic-group-1 ve11c.acme.local active false traffic-group-local-only - - -- netadmindetail_
No It's not the next active device
- nitass
Employee
- gsharri
Altostratus
Using tcpdump do you see a constant flow of traffic between the active/standby mirror addresses?
tcpdump -nni host and port 1029 Hi,
Have you got an update on this? I'm facing the same issue but I think I can break it down on the Connection Mirroring:
I'm using the same configuration on a VS for ports 80 and 443. 80 has connection mirroring enabled, 443 has it disabled because there is a clientssl profile connected to it. Both use the same iRule and I've linked the universal persistence profile to this iRule (of course mirror persistence is enabled in the profile)
I can see persistence entries for port 80 on the standby system but not for the 443 configuration.
Regards Otto
