SynACk_128568
Feb 06, 2015Persistence and snat
Hi All,
if snat2vip and persistence is configured then what will be the persistence record seen in the persistence table . I am seeing :
Sys::Persistent Connections
source-address 1.23.4.5:43 2.3.4.5:23 0
What is this source-address ?
- shaggy_121467
Cumulonimbus
what type of persistence are you using?
- SynACk_128568
Hi Shaggy, it is source ip persitence
- shaggy
- SynACk_128568
- shaggy
did you also try "show ltm persistence persist-records all-properties"?
- SynACk_128568
Thanks shaggy i can see client-addr through this command , so it will use source address not VIP for persistence ? - shaggy
what type of vip is the traffic going through? is it a wildcard VS or does the VS have a /32 address? you should see all four addresses (client IP, VIP address, SNAT, pool member) per line. a forwarding virtual server may only show the source, snat (if assigned), and destination - SynACk_128568
Thanks shaggy
- shaggy_121467
Cumulonimbus
- SynACk_128568
Thanks shaggy i can see client-addr through this command , so it will use source address not VIP for persistence ? - shaggy_121467
Cumulonimbus
Thanks shaggy
- NikhilB
Employee
You should see the source address of the client's ip. (when using snat)
