Per-Vlan Default Gateway issue
Hi;
It's my first post :) and i got a issue :( my english is not good, sorry for this. I hope, I can explain my issue with clearly.
I attach the topology for our system in post.
Our firewall have to 3 interface outside, inside and toF5. Core switch we have six vlan total. Vlan 2,4,6,7,8 and vlan 10 for outside. Per vlan have svi on core switch ip 10.10.x.1
We use two interface on F5 3600. One interface to Firewall then other interface connected to core switch that is tagged some vlan.
I want to do use F5 Floatin IP for default gateway vlan 2,4,6 you will see the topology.
I tested some example and a lot of smilar web page, but i can't solved.
https://devcentral.f5.com/tech-tips/articles/ltm-per-vlan-default-gateways
Our servers on vlan 2,4,6 must be talk each other and talk with vlan 8, 7. But their default gateway must be F5 floating ip address. They must connect to the web over the F5 LTM.
Please help for solve the problem.
Topology:
http://img835.imageshack.us/img835/8628/topology01.png
