yoni_100721's avatar
yoni_100721
May 12, 2015
Passing a variable through an iRule
How can I pass the $domain variable to the portion when CLIENTSSL_CLIENTCERT is running? Most of my work is being done during CLIENTSSL_CLIENTCERT but I would like to import the HTTP::host value.
`when HTTP_REQUEST {
  set domain [HTTP::host]
  when CLIENTSSL_CLIENTCERT {
    set cert [SSL::cert 0]
    set sn [X509::serial_number $cert]
    set subject [X509::subject $cert]
    set issuer [X509::issuer $cert]
    set version [X509::version $cert]
    set clientIP [IP::client_addr]
    log local0. $sn
    log local0. $issuer
    log local0. $subject
    log local0. $version
    if { [ class match $sn equals $domain ] ||
    [ class match $subject equals $domain ]
    log $clientIP
    log local0. "CN and Serial valid"
    else {
    log $clientIP
    log local0. "cert CN or Serial not valid"
    reject
  • Well, using
    denotes a global variable, which you wouldn't want because it's not specific to your current request/session.
    On a broader note, if you take a look at this page, part way down where the flowchart is, you can see that the
    event happens before the
    HTTP_REQUEST
    event, so you won't be able to get the hostname prior to that event.
    You might check out TLS Server Name Indication if you really want the domain in that section. Haven't played with it, but it might be worth a look.
  • Thanks for the info, I figured since clientssl_clientcert happens before HTTP_request I may not be able to get that until that phase but wanted to make sure I was on the right track.
    I ended up using the X509::subject along with trim functions to trim out the CN which is the same value in my case as the http::host.
    I started to look at TLS Server Name Indication and it might provide that ability but I haven't got that far with that.
