amebiz_142234's avatar
amebiz_142234
May 24, 2018
override variables
example
set var "foo"
if { [HTTP::uri start_with "/foobar"] } {
    set var "bar"
when HTTP_RESPONSE {
log 1.1.1.1 "logging $var"
Hi guys, for all requests which they are not start_with /foobar will be logged with "foo".
But if there a Request matched with /foobar* then there will be also logged "foo" but that should be logged with "bar"
whats going wrong here? can i not overrides existing var's? or is there a special syntax for it?
  • Hi,
    of course you can override var... try this:
    if { [string tolower [HTTP::uri]] start_with "/foobar" } {
        set var "bar"
        set var "foo"
  • Hi,
    the issue is this line:
    You must use
    [HTTP::uri]
    to get URI from HTTP request, then compare it with expected URI (move the close bracket from the end of the line to just after HTTP::uri)
    if { [HTTP::uri] start_with "/foobar" } {
