ashok_65614
Mar 17, 2010Outbound Connection
we have LTM 6900(Active/Passive) and we are using this as a proxy server for certain purposes.
Source will be our webservers and destination will be client ip's
LTM Outbound IP
Active : 192.168.100.1
Passive : 192.168.100.2
Floating : 192.168.100.3
When ever i am connecting to the client ip's the outbound connection from LTM will have the ip as my virtual(192.168.100.3)
Webserver (192.168.200.10)-----> LTM VS IP(192.168.150.10:4555)-----> 192.168.100.3 will be received as source ip in my client firewall.
LTM VS IP (192.168.150.10:4555)
Node 1 : 10.10.10.1 - Client IP 1
Node 2 : 10.10.10.2 - client IP 2
Requirement:
Need to have another outbound ip when ever i am connecting to particular LTM VS having the client node ip's.
Say :
Webserver (192.168.200.10)-----> LTM VS IP(192.168.150.20:4777)-----> 192.168.100.4 will be received as source ip in my client firewall.
LTM VS IP (192.168.150.20:4777)
Node 1 : 10.10.10.10 - Client IP 1
Node 2 : 10.10.10.20 - client IP 2
Is there any possibility to have another floating ip to be configured as like cisco MHSRP ( having multiple floating ip's)
Thanks in advance
- Cspillane_18296
Hello Ashok,
you can use a SNAT pool for this and apply it to the Virtual Server directly, or even use an iRule to reference the SNAT pool when a particular condition is met.
I hope this helps but let me know if you need more information.
