SRS_87002
Jul 26, 2007Historic F5 Account
Oracle Forms Issue - Firepass
I'm trying to access oracle forms using firepass ( i have configured the ERP portal in the Portal resource of firepass.
when i try to access the oracle forms i get the following error msg
Load:class oracle/apps/fns/formsClient/FormsLauncher.class not found
please advice,
thanks in advance.
rgds,
Ram
- Raj909_74762
I am getting the same. Please assist. - SRS_87002Historic F5 Accounttry using application tunnel..
it worked for me..
Sriram - lijeep_54639
Use
Minimal Content-Rewriting Bypass
Patterns - /OA_HTML/*
HostL Your oracle server:8003 - ccb
Employee
Hi SRS,
Could you please give an example of the syntax you used to get the application tunnel to work.
