Ryo_30997
Jan 18, 2012OneConnect with iRule
I am currently trying to set up OneConnect with iRules.
In case not want to apply OneConnect, which commands should be used as follows?
- detach enable
- detach disable
- reuse enable
- reuse disable
- hoolio
To stop using OneConnect on a single serverside connection, you can use ONECONNECT::reuse disable:
http://devcentral.f5.com/wiki/iRules.ONECONNECT-reuse.ashx
closes server-side connection after server response. (server-side connection will not be re-used.)
Aaron - hoolio
Can you add some debug logging, retest and reply with the logs from /var/log/ltm?when CLIENT_ACCEPTED { TCP::collect } when CLIENT_DATA { if {[TCP::payload] contains "XXXX" } { ONECONNECT::reuse disable log local0. "[IP::client_addr]:[TCP::client_port]: Disabling OneConnect reuse" } else { ONECONNECT::reuse enable log local0. "[IP::client_addr]:[TCP::client_port]: Enabling OneConnect reuse" } TCP::release } when LB_SELECTED { log local0. "[IP::client_addr]:[TCP::client_port]: Selected [LB::server]" } when SERVER_CONNECTED { log local0. "[IP::client_addr]:[TCP::client_port]: New connection to [IP::server_addr]:[TCP::server_port]" } when SERVER_CLOSED { log local0. "[IP::client_addr]:[TCP::client_port]: Closed connection to [IP::server_addr]:[TCP::server_port]" }
Aaron - hoolio
Hi Fumihiro,
It looks like XXXX isn't found in the payload so OneConnect isn't being disabled. Do you know how much data you need to collect in order to find the XXXX string? If so, you can include that in the TCP::collect command.
http://devcentral.f5.com/wiki/iRules.tcp__collect.ashx
Aaron - hoolio
Hi Fumihiro,
Out of curiosity, what was the solution?
Thanks, Aaron - CHSuser_16039
Default text - CHSuser_16039
Default text
