OCSP Irule help needed
I am in need of testing an irule , I am trying to direct traffic to an OCSP responder. I have compiled this Irule and need to see if this is workable?
when CLIENT_ACCEPTED {
set tmm_auth_ssl_ocsp_sid 0
set tmm_auth_ssl_ocsp_done 0
set hsl [HSL::open -proto UDP -pool SYSLOG_514_POOL]
when CLIENTSSL_CLIENTCERT {
set ssl_cert [SSL::cert 0]
if {$tmm_auth_ssl_ocsp_sid == 0} {
set tmm_auth_ssl_ocsp_sid [AUTH::start pam ncdc-ocsp-profile]
if {[info exists tmm_auth_subscription]} {
AUTH::subscribe $tmm_auth_ssl_ocsp_sid
SSL::handshake hold
log local0.debug "Client [IP::client_addr] connected with the Client Certificate: [X509::subject $ssl_cert] and checking with OCSP"
HSL::send $hsl "Client [IP::client_addr] connected with the Client Certificate: [X509::subject $ssl_cert] and checking with OCSP"
when CLIENTSSL_HANDSHAKE {
set tmm_auth_ssl_ocsp_done 1
when AUTH_RESULT {
if {[info exists tmm_auth_ssl_ocsp_sid] and \
($tmm_auth_ssl_ocsp_sid == [AUTH::last_event_session_id])} {
set tmm_auth_status [AUTH::status]
if {$tmm_auth_status == 0} {
log local0.debug "OCSP verfication succeeded, [AUTH::status]"
HSL::send $hsl "OCSP verfication from succeeded, [AUTH::status]"
SSL::handshake resume
} elseif {$tmm_auth_status != -1 || $tmm_auth_ssl_ocsp_done == 0} {
log local0.debug "OCSP verfication from error, [AUTH::status]"
HSL::send $hsl "OCSP verfication from error, [AUTH::status]"
reject
I am currently running 10.2.4 but created this irule on version 10.2.2
Regards,
Midhun P.K
- nitass
Employee
[root@ve10:Active] config b version|grep -iA 1 version BIG-IP Version 10.2.4 655.0 Hotfix HF4 Edition [root@ve10:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.252:443 ip protocol 6 auth myocsp profiles { myclientssl { clientside } tcp {} } } [root@ve10:Active] config b profile myclientssl list profile clientssl myclientssl { defaults from clientssl ca file "ca.crt" client cert ca "ca.crt" peer cert mode require } [root@ve10:Active] config b profile myocsp list profile auth myocsp { defaults from ssl_ocsp config myocspconfig type ssl ocsp credential source http basic auth rule myrule } [root@ve10:Active] config b auth ssl ocsp myocspconfig list auth ssl ocsp myocspconfig { responders myocspresponder } [root@ve10:Active] config b ocsp responder myocspresponder list ocsp responder myocspresponder { url "http://172.28.19.251:8888/" ignore aia enable certs disable verify disable nonce disable intern disable sig verify disable verify cert disable chain disable check certs disable explicit disable } [root@ve10:Active] config b rule myrule list rule myrule { when CLIENT_ACCEPTED { log local0. "--" set tmm_auth_ssl_ocsp_sid 0 set tmm_auth_ssl_ocsp_done 0 } when CLIENTSSL_CLIENTCERT { log local0. "--" set tmm_auth_ssl_ocsp_done 0 set ssl_cert [SSL::cert 0] if {$tmm_auth_ssl_ocsp_sid == 0} { set tmm_auth_ssl_ocsp_sid [AUTH::start pam default_ssl_ocsp] if {[info exists tmm_auth_subscription]} { AUTH::subscribe $tmm_auth_ssl_ocsp_sid } } AUTH::cert_credential $tmm_auth_ssl_ocsp_sid [SSL::cert 0] AUTH::cert_issuer_credential $tmm_auth_ssl_ocsp_sid [SSL::cert issuer 0] AUTH::authenticate $tmm_auth_ssl_ocsp_sid SSL::handshake hold log local0.debug "Client [IP::client_addr] connected with the Client Certificate: [X509::subject $ssl_cert] and checking with OCSP" } when CLIENTSSL_HANDSHAKE { log local0. "--" set tmm_auth_ssl_ocsp_done 1 } when AUTH_RESULT { log local0. "--" if {[info exists tmm_auth_ssl_ocsp_sid] and \ ($tmm_auth_ssl_ocsp_sid == [AUTH::last_event_session_id])} { set tmm_auth_status [AUTH::status] if {$tmm_auth_status == 0} { set tmm_auth_ssl_ocsp_done 1 log local0.debug "OCSP verfication succeeded, [AUTH::status]" SSL::handshake resume } elseif {$tmm_auth_status != -1 || $tmm_auth_ssl_ocsp_done == 0} { log local0.debug "OCSP verfication from error, [AUTH::status]" reject } } } } /var/log/ltm [root@ve10:Active] config tail -f /var/log/ltm Mar 2 23:00:36 local/tmm info tmm[22185]: Rule myrule : -- Mar 2 23:00:36 local/tmm info tmm[22185]: Rule myrule : -- Mar 2 23:00:36 local/tmm debug tmm[22185]: Rule myrule : Client 172.28.20.17 connected with the Client Certificate: CN=client1.acme.com,OU=IT,O=Acme Ltd,L=Seattle,ST=WA,C=US and checking with OCSP Mar 2 23:00:36 local/tmm info tmm[22185]: Rule myrule : -- Mar 2 23:00:36 local/tmm debug tmm[22185]: Rule myrule : OCSP verfication succeeded, 0 Mar 2 23:00:36 local/tmm info tmm[22185]: Rule myrule : -- - midhun_108442
Below is the existing configuration on my F5, but receiving error as below.Kindly verify the configuration and update your comment
BIG-IP Version 10.2.4 577.0
Final Edition
[root@RYDYDC1GSNLB01:Active] config b virtual SERVICES-T.YESSER.EGOV_443_VS list
virtual SERVICES-T.YESSER.EGOV_443_VS {
snat automap
pool SERVICES-T.YESSER.EGOV_80_POOL
destination x.x.x.x:https
ip protocol tcp
rules {
HSL-LOG
TEST_SSL-ProfileSelect_TCP-Logging
persist source_addr_yesser
profiles {
SERVICES-T.YESSER.EGOV_HTTP_X-FORWARD {}
SERVICES-T.YESSER.EGOV_ONECONNECT {}
clientssl {
clientside
tcp-lan-optimized {
serverside
tcp-wan-optimized {
clientside
vlans Lb-dmzssl enable
[root@RYDYDC1GSNLB01:Active] config b profile AGENCY_CLIENT-AUTHENTICATION_OB_02 list
profile clientssl AGENCY_CLIENT-AUTHENTICATION_OB_02 {
key "YDC_SERVICES-O.YESSER.EGOV_KEY.key"
cert "YDC_SERVICES-O.YESSER.EGOV.crt"
chain "NCDC_NRCA_GCA_SHA2CHAIN.crt"
ca file "NCDC_NRCA_SHA2.crt"
crl file none
client cert ca "NCDC_NRCA_GCA_SHA2CHAIN.crt"
ciphers "DEFAULT"
options dont insert empty fragments
modssl methods disable
cache size 262144
cache timeout 3600
renegotiate enable
renegotiate period indefinite
renegotiate size indefinite
renegotiate max record delay 10
secure renegotiation require
handshake timeout 60
alert timeout 60
authenticate once
authenticate depth 9
unclean shutdown enable
strict resume disable
nonssl disable
[root@RYDYDC1GSNLB01:Active] config b profile ncdc-ocsp-profile list
profile auth ncdc-ocsp-profile {
config ncdc-ocsp-config
type ssl ocsp
[root@RYDYDC1GSNLB01:Active] config b auth ssl ocsp ncdc-ocsp-config list
auth ssl ocsp ncdc-ocsp-config {
responders NCDC_OCSP
[root@RYDYDC1GSNLB01:Active] config b ocsp responder NCDC_OCSP list
ocsp responder NCDC_OCSP {
url "http://x.x.x.x"
nonce disable
[root@RYDYDC1GSNLB01:Active] config b rule OCSP-irule list
rule OCSP-irule {
SSL::handshake hold
when AUTH_RESULT {
reject
Logs
Sun Mar 3 11:46:17 AST 2013 info local/tmm tmm[5244] Rule TEST_SSL-ProfileSelect_TCP-Logging : TCP Connection - Started, Time: 2013-03-03 11:46:17, the Client IP: 10.1.1.29 Client Port: 8585 to 10.178.254.30:443
Sun Mar 3 11:46:22 AST 2013 debug local/tmm tmm[5244] Rule OCSP-irule : Client 10.1.1.29 connected with the Client Certificate: CN=demo.yesser.gov.sa,OU=YESSER CSP,OU=Government CA,O=National Center for Digital Certification,C=SA and checking with OCSP
Sun Mar 3 11:46:22 AST 2013 debug local/tmm tmm[5244] Rule OCSP-irule : OCSP verfication from error, 1
Sun Mar 3 11:46:22 AST 2013 info local/tmm1 tmm1[5245] Rule TEST_SSL-ProfileSelect_TCP-Logging : TCP Connection - Started, Time: 2013-03-03 11:46:22, the Client IP: 10.1.1.29 Client Port: 8586 to 10.178.254.30:443
Sun Mar 3 11:46:26 AST 2013 debug local/tmm1 tmm1[5245] Rule OCSP-irule : Client 10.1.1.29 connected with the Client Certificate: CN=demo.yesser.gov.sa,OU=YESSER CSP,OU=Government CA,O=National Center for Digital Certification,C=SA and checking with OCSP
Sun Mar 3 11:46:26 AST 2013 debug local/tmm1 tmm1[5245] Rule OCSP-irule : OCSP verfication from error, 1
Sun Mar 3 11:46:26 AST 2013 info local/tmm tmm[5244] Rule TEST_SSL-ProfileSelect_TCP-Logging : TCP Connection - Started, Time: 2013-03-03 11:46:26, the Client IP: 10.1.1.29 Client Port: 8587 to 10.178.254.30:443
Sun Mar 3 11:46:31 AST 2013 debug local/tmm tmm[5244] Rule OCSP-irule : Client 10.1.1.29 connected with the Client Certificate: CN=demo.yesser.gov.sa,OU=YESSER CSP,OU=Government CA,O=National Center for Digital Certification,C=SA and checking with OCSP
Sun Mar 3 11:46:31 AST 2013 debug local/tmm tmm[5244] Rule OCSP-irule : OCSP verfication from error, 1
Sun Mar 3 11:46:31 AST 2013 info local/tmm1 tmm1[5245] Rule TEST_SSL-ProfileSelect_TCP-Logging : TCP Connection - Started, Time: 2013-03-03 11:46:31, the Client IP: 10.1.1.29 Client Port: 8588 to 10.178.254.30:443 - Kevin_Stewart
Employee
At the very least you're not including the AUTH::authenticate section in your code, which sends the OCSP request (and certificate data) to PAM.AUTH::cert_credential $tmm_auth_ssl_ocsp_sid [SSL::cert 0] AUTH::cert_issuer_credential $tmm_auth_ssl_ocsp_sid [SSL::cert issuer 0] AUTH::authenticate $tmm_auth_ssl_ocsp_sid
I'm actually a little surprised that AUTH_RESULT is even firing, but the error indicates that the process failed. If you watch the network traffic with TCPDUMP, I'm guessing that you never see an OCSP request leave the BIG-IP. - midhun_108442
I Updated the script with AUTH section , but getting an error as below
Mar 4 11:12:44 local/tmm1 info tmm1[5245]: Rule TEST_SSL-ProfileSelect_TCP-Logging : TCP Connection - Started, Time: 2013-03-04 11:12:44, the Client IP: 10.1.1.29 Client Port: 17774 to 10.178.254.30:443
Mar 4 11:12:49 local/tmm1 err tmm1[5245]: 01220001:3: TCL error: while executing "AUTH::cert_credential $tmm_auth_ssl_ocsp_sid [SSL::cert 0]"
Mar 4 11:12:49 local/tmm info tmm[5244]: Rule TEST_SSL-ProfileSelect_TCP-Logging : TCP Connection - Started, Time: 2013-03-04 11:12:49, the Client IP: 10.1.1.29 Client Port: 17775 to 10.178.254.30:443
Mar 4 11:12:53 local/tmm err tmm[5244]: 01220001:3: TCL error: while executing "AUTH::cert_credential $tmm_auth_ssl_ocsp_sid [SSL::cert 0]"
Mar 4 11:12:54 local/tmm1 info tmm1[5245]: Rule TEST_SSL-ProfileSelect_TCP-Logging : TCP Connection - Started, Time: 2013-03-04 11:12:54, the Client IP: 10.1.1.29 Client Port: 17776 to 10.178.254.30:443
Mar 4 11:12:58 local/tmm1 err tmm1[5245]: 01220001:3: TCL error: while executing "AUTH::cert_credential $tmm_auth_ssl_ocsp_sid [SSL::cert 0]"
Mar 4 11:12:58 local/tmm info tmm[5244]: Rule TEST_SSL-ProfileSelect_TCP-Logging : TCP Connection - Started, Time: 2013-03-04 11:12:58, the Client IP: 10.1.1.29 Client Port: 17777 to 10.178.254.30:443
Mar 4 11:13:03 local/tmm err tmm[5244]: 01220001:3: TCL error: while executing "AUTH::cert_credential $tmm_auth_ssl_ocsp_sid [SSL::cert 0]" - Kevin_Stewart
Employee
Given that you're not doing too much customization, I recommend starting with a copy of the default OCSP iRule to make sure your other configurations are correct, and then add your logging statements after you know everything else works.
