cvandal_163340
Jul 13, 2014Obtain Node Name by Node Description Using PowerShell
Hello,
Is it possible to obtain a node's name by looking at the node's description using PowerShell? Almost every node within our environment doesn't have a friendly node name however the description matches the node's hostname. I'm thinking if I could store every node and that node's properties in an array, search for the description, and if found determine the name.
Hi mate
Try this one?
Initialize Snapin if ( (Get-PSSnapin | Where-Object { $_.Name -eq "iControlSnapIn"}) -eq $null ){ Add-PSSnapIn iControlSnapIn } Setup credentials $User = "user" $Password = "password" $BigIP = "10.10.10.10" Add a type/class to store the node data in Add-Type @' public class Node { public string Name; public string IP; public string Description; public string Partition; } '@ Create an empty array to store the node objects in $Nodes = @() Connect to the BigIP and get an iControl Handle $Success = Initialize-F5.iControl -HostName $BigIP -Username $User -Password $Password $F5 = Get-F5.iControl Get the partition list $f5partitions = $f5.ManagementPartition $partitionlist = $f5partitions.get_partition_list() Loop through each partition saving node information $partitionlist | foreach-object { $Partition = $_.partition_name $f5partitions.set_active_partition("Common") $NodeNames = $f5.LocalLBNodeAddressV2.get_list() $NodeIPs = $f5.LocalLBNodeAddressV2.get_address($NodeNames) $NodeDescriptions = $f5.LocalLBNodeAddressV2.get_description($NodeNames) for($i=0;$i -lt ($NodeNames.Count);$i++){ $objTempNode = New-Object Node $objTempNode.Name = $NodeNames[$i] $objTempNode.IP = $NodeIPs[$i] $objTempNode.Description = $NodeDescriptions[$i] $objTempNode.Partition = $Partition $Nodes += $objTempNode } }That will store your node information in $Nodes. You can filter by using ie. where-object:
$nodes | Where-Object { $_.description.Contains("WEB") }Hope that's what you're looking for?
Kind regards, Patrik
