Null Values comming from IControl
I had a script that was running until a few days ago and now all of a sudden it doesn't output anything. When I run it against the active node it doesn't work but when I put it to the standby node it does. Also when I change the username to a different username it works but when I leave it as foo on the active node it doesn't return anything. Here is bascally what my python script dos
c = pycontrol.BIGIP(
hostname='1.2.3.4',
username='foo',
password='bar',
fromurl=True,
debug=True,
wsdls=['LocalLB.Class']).LocalLB.Class
for data in c.get_address_class_list():
print data
Now this is what it spits out
DEBUG:suds.client:headers = {'SOAPAction': u'"urn:iControl:LocalLB/Class"', 'Content-Type': 'text/xml'}
DEBUG:suds.client:http succeeded:
xmlns:E="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:A="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:s="http://www.w3.org/2001/XMLSchema-instance"
xmlns:y="http://www.w3.org/2001/XMLSchema"
xmlns:iControl="urn:iControl"
E:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
xmlns:m="urn:iControl:LocalLB/Class">
s:type="A:Array"
A:arrayType="y:string[0]">
Is there any reason this would not work on the active node with username foo but works with a different username or on the standby node?
- mhite_60883
Cirrocumulus
Totally random guess, but perhaps the partition/folder context is different when you perform your iControl call with a different user or target load balancer. If you don't use sessions, I believe you inherit that last folder/partition context that was set with that account.
