Jeepha_42175's avatar
Jeepha_42175
Apr 04, 2008
Noob (not a boob) needs Help with Setup
Hello, I'm such a newbie that I cant seem to find a newbie forum.
Anyhow, My company has an older 2400 big IP LTM that has never been configured. It is running 4.x kernel.
At any rate, I am unable to communicate properly with the Serial interface. I have tried a few different VT100 emulators to start the config process.
I can boot the F5 and watch the sequence, however I cant seem to type any response to the system. I want to log in as root and run the config setup..but nothing happens when type..the cursor just sits there and taunts me, unmoving.
I'm sure this post is as green as it gets...but I assure you once I get to where I can actually type into the console I will gain a rarely reached level of 'dangerous'.
Please help if you can...
Thank you~!
  • I had the exact same issue one time. Turns out it was my my terminal dongle
    Here are a couple of links to help you diagnose your issue
    Click here (need a account for F5's Ask Knowledgebase)
    Hope this helps.
    CB
