mjohns2_184959's avatar
Apr 05, 2015
Node Connection Fails By Pool
Coming from the Cisco ACE Load Balancer, I frequently check the status of the nodes members (real servers) by using the following command:
ACE/C15 show server farm SERVERFARMNAME
serverfarm : SERVERFARMNAME, type: HOST
total rservers : 5
                                            ----------connections-----------
   real                   weight  state     current       total      failures
rserver: SERVER0
   192.168.1.100:0         8      OPERATIONAL  506          0          0
rserver: SERVER1
   192.168.1.101:0         8      OPERATIONAL  519          0          0
rserver: SERVER2
   192.168.1.102:0         8      OPERATIONAL  501          0          0
rserver: SERVER3
   192.168.1.103:0          8      OPERATIONAL  511          0         0
rserver: SERVER4
   192.168.1.104:0          8      OPERATIONAL  490          0         42
This gives me a quick glance at the status of each of the servers in the server farm. More importantly, I can see the errors (no SYN response or reset from the server).
Is there an equavalent command to "show serverfarm SERVERFARMNAME" on F5, "show ltm pool SERVERFARMNAME" doesn't appear to have a column for failures.
Thank you,
MJ
  • LTM does not track per-node/pool member connection failures so you will not see any connection failed stats for individual nodes.
    A health monitor assigned to node/pool member will generate a log msg and snmp trap when marking an object up or down.
    Failures can also be seen at the layer 4 profile level for a virtual server:
    tmsh show ltm profile tcp profile_name
    Or other errors in tmm stats:
    tmsh show sys tmm-traffic
  • TechT's avatar
    TechT
    Hi MJ, If you are looking out for a reset from the server , you can try running tcpdump on cli and see the packet capture output if reset is coming from the server end or not.
    SYNTAX: tcpdump -nni 0.0 host x.x.x.x
