elonecoder_2690
Aug 13, 2009No System Menu
Hello folks,
Trying to configure a Big-IP 3400, there is no System Menu on the LCD display, only Options.
I had the same problem with the other twin LB and I fiddled around with the buttons and the System Menu appeared.
Please advise.
T
- hoolio
I think the system menu is available when the lcdd is running. I think this process only starts once the unit is licensed. Can you connect via the management or serial ports and ensure the license is valid?
Aaron
