ussamaabdulrahman's avatar
ussamaabdulrahman
Feb 25, 2024
NGINX Plus was installed but License does not work.
I installed NGINX plus with the CRT and Key and it works fine but the license does not work so what is the problem?
  • you got the license from the MyF5 portal? might be easiest to contact support then.
