NetScaler to F5 problems with cookies
Hey guys,
Working a project where I'm taking a netscaler VIP to the LTM. The old VIP used content switching (uri based pool section). As you may know, cookie persistence is set at the pool (serviceGroup) level on the NS, hence this iRule.
switch -glob [string tolower [HTTP::path]] {
*/301* { pool pool_301_8080
persist cookie insert NSC_bgn301 "0d 00:00:00" }
*/302* { pool pool_302_8080
persist cookie insert NSC_bgn302 "0d 00:00:00" }
*/303* { pool pool_301_8080
persist cookie insert NSC_bgn303 "0d 00:00:00" }
*/304* { pool pool_305_8080
persist cookie insert NSC_bgn304 "0d 00:00:00" }
default { pool pool_whatever_80 }
when HTTP_RESPONSE {
set myValues [HTTP::cookie NSC_bgn301 NSC_bgn302 NSC_bgn303 NSC_bgn304 NSC_bgn305]
foreach mycookies $myValues {
HTTP::cookie secure $mycookies enable
Problem 1: Cookies NSC_bgn30X all expire after 180 seconds, not session.
Problme 2: Cookies are still not secure
Problem 3: Need to set HostOnly flag to true.
FYI:
Main Package
Product BIG-IP Version 10.2.3 Build 123.0 Edition Hotfix HF1 Date Fri Dec 2 11:43:17 PST 2011
Any help is greatly appreciated.
Brian
- Brian_Deitch_11Historic F5 Account
I have found the root cause:
http://support.f5.com/kb/en-us/solutions/public/11000/600/sol11679.htmlIn short, you cannot set the persistence record to session.
I'm going to try to rewrite the value using HTTP_RESPONSE. If I have any luck, I will communicate it out.
Ok
Is now:when HTTP_RESPONSE { set myValues [HTTP::cookie NSC_bgn301 NSC_bgn302 NSC_bgn303 NSC_bgn304 NSC_bgn305] foreach mycookies $myValues { HTTP::cookie secure $mycookies enable } }
Unfortunately thewhen HTTP_RESPONSE { set myValues [HTTP::cookie names] foreach mycookies $myValues { HTTP::cookie secure $mycookies enable HTTP::cookie expires $mycookies 0 } }
doesn't work. It defaults back to 180 seconds.HTTP::cookie expires $mycookies 0 - Brian_Deitch_11Historic F5 AccountFinal workaround:
when HTTP_REQUEST { switch -glob [string tolower [HTTP::path]] { */301* { pool pool_301_8080 persist cookie insert NSC_bgn301 "1d 00:00:00" } */302* { pool pool_302_8080 persist cookie insert NSC_bgn302 "1d 00:00:00" } */303* { pool pool_301_8080 persist cookie insert NSC_bgn303 "1d 00:00:00" } */304* { pool pool_305_8080 persist cookie insert NSC_bgn304 "1d 00:00:00" } default { pool pool_whatever_80 } } } when HTTP_RESPONSE { set myValues [HTTP::cookie names] foreach mycookies $myValues { HTTP::cookie secure $mycookies enable } }
Since I was unable to set the persistence timeout to 0(session), I had to set it to 1 Day (1d 00:00:00). Securing cookies now works as I had passed the wrong argument in the original post.
