Need translated iRule for bigip: 11.4
Hi guys , i know its very silly but can any one help me to translate the following iRules form ver 11.3 to 11.4, thanks in advance.
RPC_ASM_irule
when HTTP_REQUEST { if { ([HTTP::path] eq "/rpc/rpcproxy.dll") and \ (([HTTP::method] equals "RPC_IN_DATA") or ([HTTP::method] equals "RPC_OUT_DATA"))}{ set rpcdata 1 } else { set rpcdata 0 } } when HTTP_CLASS_SELECTED { if { $rpcdata == 1 }{ ASM::disable } else { ASM::enable } }
- Kevin_Stewart
Employee
I believe, despite the wiki article saying otherwise, that you can just do this:
when HTTP_REQUEST { if { ( [HTTP::path] eq "/rpc/rpcproxy.dll" ) and ( ( [HTTP::method] equals "RPC_IN_DATA" ) or ( [HTTP::method] equals "RPC_OUT_DATA" ) ) } { ASM::disable } } - What_Lies_Bene1
ASM processing is enabled by default, hence you don't need to enable it.
